Overview
This example demonstrates how to programmatically edit groups and channels on an existing TDMS file within LabVIEW.
See KB 4TE9SRQ2: Can I Delete Channels or Properties from a TDMS File with LabVIEW?
Description
The project contains two VIs (and example data files). The main VI creates a new TDMS file with three groups, each with its own channel and data. The subVI is then called to convert the TDMS file to a TDM file in order to remove the specificied group. Finally, the main VI opens a TDMS File Viewer to observe the TDMS changes.
Requirements
