Example Code
Modified file to eliminate write at VI start
Code and Documents
Overview:
This VI shows how to control logging when the amplitude changes.
Description:
This Vi simulates a signal and uses the amplitude and level measurements to detect a change on the signal and decides to log a file.
Requirements:
LabVIEW Base Development System (or compatible)
Steps to Implement or Execute Code:
1. Specify the Amplitude Trigger and how long to write to file.
2. Turn the Amplitude slide bar below your specified Amplitude Trigger.
3. Run the VI
4. Select the name of the file to save.
5. Slowly slide the Amplitude bar up.
Additional Information or References:
Comments
HunterSeeker
Member Member
Member
on
Could you add a screenshot for this example?
