Example Code
Mini Calculator in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to implement a calculator based on software buttons, using the Event-Driven Producer and Consumer design pattern.
Description
The User Interface emulates a calculator keypad. These software buttons are triggered based on an Event-Driven Producer and Consumer design pattern and allows the user to add, subtract, multiply and divide two numbers.
Requirements
  • LabVIEW 2013 (or compatible)
  1. Run Calculator 2013 NIVerified.vi
  2. Use the keypad to add, subtract, multiply and divide two numbers.
  3. For example, you can click the following software keys in the following order:
    1. Click "1"
    2. Click "+"
    3. Click "3"
    4. Click "E"
    5. Notice that the result is 4, which is 1 +3
    6. Click "C" to clear the calculator input
  4. Press the "Stop Button" to exit the program.
Additional Information or Resources
VI Block Diagram
