Overview
This VI shows how to merge two signals together and then display it on a graph.
Description
There are a couple of ways of doing this but this is one (another would be to use the Merge Signals.vi). We create two signals using the Simulate Signal Express VI for a Sine Wave and a Random Number generator for the other signal. We use Initialize Array, Replace Array Subset, and Shift Registers to combine the Random Number data into a 1D Array. After the While Loop stops when the set number of data points are recieved, we combine the two 1D Array into a 2D array using Build Array and then pass that into a Waveform Graph. When you run the VI you will notice that both signals will be displayed on the graph. Try this out but remember that there are a bunch of different ways to accomplish anything in LabVIEW.
Requirements
Software:
- LabVIEW 2012 (or compatible)
- Enter a "Number of samples"
- Run the VI.
Additional Information or Resources
