Example Code
Measuring Execution Time of a Code using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example VI enable you to measure the execution time of a code.
Description
This basic VI allows you to measure the execution time of the code in the middle segment of the sequence structure. This can be useful for troubleshooting and for performance metrics. In the VI, two tick counters are used to measure the difference in time between the starting and ending. The execution time is shown in milisecond.
Requirements
  • LabVIEW Base Development System 2012 (or compatible)
  1. Open the VI "Execution Time 2012 NIVerified.vi"
  2. Run the program.
VI Block Diagram
Bogdan Buricea
