Example Code
Measure Pixel Height using LabVIEW
Products and Environment
    Software
  • Vision Development Module
  • LabVIEW
Code and Documents
Overview
This example VI shows how to measure the pixel height in an image.
Description
This example shows how to measure the pixel thickness of a particle. It outputs the number of vertical pixels by measuring with the IMAQ Edge Detection VI.
Requirements
 Software
  • LabVIEW Base Development System 2012 (or compatible)
  • NI Vision Development Module 2012 (or compatible)
 Hardware
  • No hardware is necessary to use this example VI
  1. Download and open the attached file
  2. Run the program
Measure Pixel Height LV 2012 NIVerified.vi - Front Panel.pngMeasure Pixel Height LV 2012 NIVerified.vi - Front Panel.png
Measure Pixel Height LV 2012 NIVerified.vi - Block Diagram.pngMeasure Pixel Height LV 2012 NIVerified.vi - Block Diagram.png
**The code for this example has been edited to meet the new Community Example Style Guidelines. The edited copy is marked with the text ‘NIVerified’. Read here for more information about the new Example Guidelines and Community Platform.**
Comments
raja17
Member
Member
on
what is the method to find thickness of paricular object in an image acquired from camera using ni vision?
I want to quantify the thickness..
Can anybody help me with this??
