Overview:
This VI demonstrates on measuring the rotation of an incremental quadrature encoder using the DAQ-STC counter on E-series DAQ cards.
Description:
Connect phase A of the encoder to the SOURCE of counter 0 and connect phase B to DIO 6 which is the Up/Down line for counter 0.
If you configure Counter 0 for Hardware Up/Down counting, Counter 0 counts up when the Up/Down line is high and down when the Up/Down line is low.
If counting on the rising edge of phase A, the Up/Down line will be high when rotating clockwise (CW) and low when rotating counter-clockwise (CCW).
Requirements:
LabVIEW 2012 or compatible.
NI-DAQmx 15.5.1 or compatible.
DAQ-STC counter.
Steps to Implement or Execute Code:
Block Diagram Steps:
connections
In my case result is correct if I connect signals A and NOT B (B inv.).
Can someone please mail me this VI that is compatible with LabVIEW 8.0 . My mail id is rajnish14feb@gmail.com
