Example Code
MathScript Node Input Parse String Array
Code and Documents
Overview
LabVIEW makes it very easy to append or concantenate an array of strings, but the MathScript node implements this functionality differently. This example demonstrates how to concanentate arrays of strings, removing some of the blanks.
Description
The code in the MathScript node works as follows:
Line number:
1: Declaring a variable which uses the size function built into the node to get the size of the input array (in this case first names)
2: Doing the same thing on the second input array (last names)
4: Creating a final output variable
6: Comparing sizes of the array to look for issues in sizes
7: Starting the search of array lengths
8: Building string1
9: Building string2
10: Concantenating the strings together using the strconcat function.
11: End
12: End
Additional functions which could be added:
deblank to get rid of the additional spaces
Requirements
  • LabVIEW 2012 (or compatible)
  • MathScript 12.0 (or compatible)
  1. Download and open Mathscript String.vi
  2. Type in several first names to Array
  3. Type in several last names to Array 2
  4. Press the run button - the VI will populate the final array with the first name/last name combinations
VI Snippet
Sam S
