Example Code
Master/Slave Architecture Using Notifiers With Two Slave Loops
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code show how master/slave architecture work with notifiers, and these two slave loop  will run independently of each other.
Description
In this example, the Master loop continues to loop and the case structure checks whether the switch on the front panel has been pressed or not. When the button is pressed, two string notifiers are sent, "Loop 1" and "Loop 2".
Each slave loop contains a check to see if it should execute. Each loop blinks a respective LED on the front panel at a different rate.
When the application begins, nothing will be happening. Then, when you press the Switch button, the LED's will blink a set number of times, each at a different rate specified by the wait contained in the for loop in each slave loop. After the LED's have finished blinking, they will turn off, and they will again be waiting for the Switch button to be pressed. Additional slave loops can be added to this architecture as needed.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run VI
VI Block Diagram
Robert B
RF Product Support Engineer
Comments
mtedaldi
Member
Member
on
This example is nice. But only useful if you do not care about lost notifications and quite random behavior.
Sometimes, Loop1 might get a notification for Loop2 (and therefore do nothing) and the other way around if not both loops are waiting for a notification at the same time. The problem becomes apparent when you click on the switch after about 9.5s...
So use with care 🙂
Marco Tedaldi, University of Zurich, CLAD
RyanG_EE
Member
Member
on
I know this is is an older thread that I just stumbled upon, but I believe the solution to the OP's problem is to use a Producer-Consumer design pattern, rather than a Master-Slave design, correct?
USBarnes
NI Employee (retired)
on
The only real way to ensure that no events are missed would be to use a queue or some structure that contains previous points, or some way of handshaking between loops. I will admit, my LabVIEW knowledge (especially for notifiers) was rather new when I created this example. It was intended to show the parallelism of loops in LabVIEW, however as mtedaldi pointed out, it will become less predictable as the program runs.
Robert B
