Example Code
Manipulating Text Files Example:
Code and Documents
Description: This VI generates a table of data; in this instance the data is random. Using the functions in LabVIEW this VI demonstrates how to determine the number of data rows that are contained within the array and then how to, using our string and write to text file functions create headings and titles for those data columns in LabVIEW and save them to a file.
This example is written for LabVIEW: 2010
Additional modules: No additional modules required just pure 100% LabVIEW
Instructions: Create a blank text file and save it to an appropriate location. Open the VI and select that text file in the file location box on the front panel, select a table size and run. View your populated text file in excel after running.
Front Panel:
Block Diagram:
Regards
Andrew George @ NI UK
Contributors
