Example Code
Managing many boolean indicators programatically, such as DSC 3D Pipes
Code and Documents
Introduction
In this VI is shown how to change the color of multiple pipes in the front panel programatically. For example, we have two lines, the hot and the cold line. The cold line has four states, dependig of some conditions, in this case, pressure and temperature. If pression is over the pressure set point then the whole pipe must be blue, if the temperature is over the temperature set point then the whole pipe must be orange, etc.
Software Requiered
LabVIEW 8.6
LabVIEW DSC Moduel 8.6
Arturo Gómez | Applications Engineering
Certified LabVIEW Associated Developer
National Instruments Latin America
01-800-010-0793
ni.com/support
Contributors
