Example Code
Make Color Map for Image Manipulation
Code and Documents
Overview
This SubVI takes in the percentage of Red, Green, and Blue from an image and creates a Color Map that can be applied to any 8 bit image using Flatten Pixmap.
Description
The Create Color Map.vi creates a scaled color mask that is applied to the 8-bit BMP image file's color properties. By using a scaled color percentage for Red/Green/Blue, which are found by converting each vaule to an 8-bit unsigned integer, ranging from 0-255, the values are returned as a 1D array of colors. This array, is then fed into the image data colors element of the Bundle by Name, and it is then flattened into a pixmap for image display.
Caveats and Additional Notes
Color Maps will not work on 24+ bit images.
  1. Specify the path to your desired 8-bit BMP file on the Color Map Demo.vi Front Panel
  2. Run the VI
  3. Change the RGB percentage sliders to manipulate the image
Requirements
Software
LabVIEW 8.6 or later
Additional Images or Video
VI Snippet
**This document has been updated to meet the current required format for the NI Code Exchange. For more details visit this discussion thread**
Contributors
