Example Code
MPI S7 Protocol Example
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
This example was manually migrated for Marcopolo5 - last modified <span class="documentModified">2008-02-07 08:10
Overview
This example provides a library of LabVIEW VI's that can be used to communicate with a Siemens S7-300 PLC via the MPI port.
Description
This example communicates with a S7-300 PLC through a Simatic S7 PC Adapter (MPI to RS-232 adapter). Communication with the Simatic PC MPI adapter is based on the 3964r protocol and communicates via RS-232. The example provides an API to read from / write to registers on the PLC.
This example was not created from a protocol specificaion, but through reverse engineering sample data sent between a PC and S7 PLC. Use at your own risk.
Also included is an example of using a cRIO-901x contoller as a data logger for MPI data. The program logs data from registers listed in the "MPI Read Write Array". Data is saved on the internal flash memory and is automatically transfered to USB drive when one is connected to the external USB port of the cRIO.
Steps to Implement
  1. Download and extract zip file.
  2. Open Siemens MPI.lvproj
  3. Run MI Test.vi or MI Test 2.vi
Requirements
Software
-LabVIEW
Hardware
-Siemens S7-300 PLC
-cRIO-901x
Additional Images
Best,
JLSx
Sixclear
VI High - LabVIEW Programming Video Blog
Comments
effgee
Member
Member
on
Sounds good; can anyone downsave this to v7.1 or earlier ? Please !
cdiaz
Member
Member
on
I was looking for a example like this. But I wonder if you know what requirements are needed to establish communication between the PLC S7300 Siemens and a PC using the software Labview 8.6. I've already done all the steps that are in the tutorial video from NI, and also forums, however I was unable to establish this communication.
I appreciate being able to help with this problem
______________
Cesar Diaz
Ing. Mecatrónico
seriasoneub
Member
Member
on
Habe dieses Programm genutzt. Speichere damit Datenbausteine in Excel.Aber bei MPI-Adressen
größer 2 versagt der Kommunikationsaufbau. Warum ?
I used this program to save db's in excel files. Works more than fine. Except mpi-addresses greater
then 2. Why? Error 6201 is send back. I have no idea where to search.
In sub VI "MPI_PLC_Connect" answer of first mpi-state-machine is only 8 bytes long instead of 23.
And output ( content of this first mpi-state-mach. ) differs from the expected shown in array at "equal"-
element.
Contributors
