Example Code
MCB 2300 / LPC2378 SPI Reference Design
Code and Documents
The ARM SPI Create Configuration Reference vi in Labview embedded module has a little flaw with chip select input.
Infact it selects spi interface not the chip. (LPC2378 has 2 spi interfaces on it).
So it is necessary implementing Chip Select manually.
Here is a working (tested) SPI reference design for MCB2300 and LPC2378 microcontrolers.
Manuel chip select capability added to original SPI VIs.
                       Figure1.  Example usage.
                       Figure2.  Manuel Chip select.
Comments
Himmet
Active Participant
Active Participant
on
Thanks...
Contributors
