Overview
This example shows how you can process a signal on your host computer using a Lowpass Filter Workspace Tool for Veristand.
Introduction
NI VeriStand is an open environment that can be customized in a variety of ways. NI VeriStand provides the user with a number of built-in workspace tools for signal monitoring and processing. Many applications, however, feature unique needs that can benefit from customized tools. The Lowpass Filter Workspace Tool allows the user to select a system definition channel, configure a lowpass filter for that channel and display the original and the filtered signal inside the workspace.
The example code comes with a Veristand project that you can use to test the functionality of the Lowpass Filter Workspace Tool. The project includes a model that generates a sine wave of a given frequency with a given noise amplitude and displays this signal on a workspace graph.
1. Run the SineWave.nivsproj Veristand project
2. In the Project Explorer window go to Tools » Workspace Tools » Custom Tool and select the Lowpass Filter Workspace Tool.vi
3. Select Aliases/Sinwave channel
Requirements
Software
Veristand 2011 or Veristand 2012
Hardware
N/A
Additional Notes
For more information on creating and modifying custom workspace tools refer to Adding a Custom Tool to the NI VeriStand Workspace tutorial.
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
Hi, I am using 2013 version of Veristand and LabVIEW. I unable to add 'LowPass Filter' as custom device, When I tried to open "LowPass Filter Workspace Tool.vi" LabVIEW is looking for NationalInstruments.Veristand.SystemStorage.dll, and couldn't able to locate this file.
Can some one help me on this. Thanks
Michael
