Example Code
Look Up Table FGV
Code and Documents
Overview
This is an Functional Global Variable that behaves as a lookup table.
Description
You can set values of the look up table as well as retreve them. Any set values will return to default
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download the attachment to your computer
  2. Open the VI "Look Up Table 2012 NIVerified.vi"
  3. Run the VI
VI Snippet
Matthew Trott
National Instruments UK
www.ni.com/ask
Comments
jordankuehn
Member
Member
on
http://i.imgur.com/f0Lqg.png
Unless your array contains all the integers, it does not function as described in the BD comment.
The Colex Group
Lead Software Engineer
Certified LabVIEW Developer
