Overview
These two codes are long time pre-trigger image streaming application and the file reader.
Description
For long time pre-trigger image streaming application like 10 minutes, we need to use binary file as circular buffer because cannot use memory area like queue.
Requirements
Software
LabVIEW 2015 or compatible
NI-IMAQdx 15.5.0 or compatible
Hardware
Camera for IMAQdx
(I use PC camera of DELL latitude E7250. And I set the PC camera to RGB_U32 in MAX because the code is for RGB_U32.)
<MAX>
1. Set Camera to RGB_U32 in MAX.
<Image streaming to binary file with Long time pre-trigger.vi>
1. Open the VI.
2. Set the File Path if needed.
3. Select the Camera Name.
4. Set the Pretrigger size.
5. Run the VI.
6. Push the Trigger button.
7. Push the Stop button.
<Read Binary File with header info.vi>
1. Open the VI.
2. Set the File Path.
3. Run the VI.
<Header Info>
The header info is prepended to the binary file, and file reader application uses the header info to read image in order from the binary file.
<“Pre_trigger” state>
"Image streaming to binary file with Long time pre-trigger.vi" is state machine code, and, on "Pre_trigger" state, it stores the image to binary file as circular buffer.
<“Trigger detection” and “Post_trigger” state>
On “Trigger detection” and “Post_trigger” state, the code stores image as below.
If these codes don't match your application, please improve this code on your own.
