Example Code
Logging Fewer Samples of Data Than Acquired in LabVIEW With The Write to Measurement File
Code and Documents
Overview
Some applications require a set sampling rate and sample size for other purposes of the code. When data logging is involved, this may cause a generated measurement file to be overly saturated with sample data, making analysis difficult. This example provides a workaround using condition logging.
Description
This example can be used to generate a measurement file that has fewer samples than the sampling rate and sample size provides. When the sample size to sampling rate ratio cannot be adjusted for logging purposes, this is an option for having a simplified data log. The Number of Total Data Samples Written in the measurement file is the Number of Total Samples Written divided by the Sample Rate Divisor rounded to the nearest number divisible by Number of Samples.
  1. Download the VI from below.
  2. Open and configure the Front Panel controls.
  3. Run the VI.
Requirements
Software
Hardware
DAQ
Additional Images or Video
Briana P.
Licensing
Sr SW Engineering Manager | NI R&D
ni.com/support
Contributors
