Example Code
Logging Data apart from Zero
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Coding that exemplifies how to log all data different from zero.
Description
Run the program, adjusting the value in the control. All results but 0 will be logged. You can adjust the timer value on the block diagram to set how often you want to log data. To log data only above 0.01, change this to 0.01.. etc. You can build from this example to fit your application needs.
Requirements
LabVIEW 2012 or compatible
1. Run the VI.
2. Change the control value.
3. Stop the execution with the Stop Button.
4. Search the file and look at the values written.
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
Comments
Rod42
Active Participant
Active Participant
on
Not quite.
The selector in a case statement can only be a boolean, string, integer or enumerated type. Notice that the selector is coloured blue and has a red dot showing that your double has been coerced to an integer. The coercion is by rounding, so as written it will log any value above 0,5
One way to achieve the result you seek is by doing a test on the value and using the boolean of the result as the case selector.
