Example Code
Log Keystroke Data Using Events in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code allows logging into an array of string every key pressed by the user.
Description
This example allows you to log keyboard input without needing to make sure a string control is selected. As long as the VI is active, this VI will log and record all keystrokes. This is useful for hardware which generates keyboard strokes, including many barcode scanners and some instruments.
Requirements
LabVIEW Base Development System (or compatible)
1. Run the VI
2. Press any key of letters or numbers
3. Watch the key added to the array
4. Click the Stop button to finish execution
Al B.
Staff Software Engineer - TestStand
CTA/CLD
