Example Code
Lock a Tab in a Tab Control in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example shows how to the user can lock (disabled and greyed) a tab on the front panel
Description
This VI  uses a property node to return an array of pages within a tab control.  It then indexes a page out of the array and sets it to Disabled & Grayed.  The Lock/Unlock control on the front panel prompts the user for the password "engineer".  If password is correct the indexed page's status is reversed to either enabled or disabled & grayed depending on its current state.
Requirements
LabVIEW Full Development System 2012 or compatible
  1. Run the VI
  2. Notice that Tab 2 is Disabled and Greyed out by default
  3. Click on Lock/Unlock button to change the enabled state
  4. Enter a selected password, in this case it is "engineer"
  5. Notice that Tab 2 has now switched states, from enabled to disabled or from disabled to enabled
VI Block Diagram
**This document has been updated to meet the current required format for the NI Code Exchange. **
Jon S.
LabVIEW NXG Product Owner
Comments
surfnska
Member
Member
on
Perfect! I've been wanting to disable a tab for a while if a certain condition existed, but settled on disabling certain controls.
briguy68b
Member
Member
on
Hello, I am new to labview and am working on a program that a collegue made. I want to disable a tab when the user clicks the run button. I have looked at your example tryig to modify it to make it work for whaT I am trying to do but I am not knolewgable enough at this point to figure it out.
Jon_S.
NI Employee (retired)
on
You can use the Page Enabled property from above to disable and gray out a tab when your VI starts.  Just make it one of the first things that execute.
Jon S.
