Overview
This VI allows for allows for selective loading of different channels of data blocks to standard LV using data plugins posted on www.ni.com/dataplugins. However, can be easily modified for different plugins.
Description
This example shows how to load all channels from a DataPlugin file. If the data is stored as a waveform it is graphed vs. the waveform time values, otherwise it is graphed vs. the array index.
Requirements
LabVIEW Base Development System.
Desired DataPlugin from www.ni.com/dataplugins
1. You need to register the DataPlugin before you can run the VI.
2. Select the path of the file you wish to view.
3. Enter the name of the Data Plugin to use to load that file.
4. Run the VI.
Song, thanks for posting. Please rename your VI to include the LabVIEW version ("_lvXX.vi" is fine).
