Overview:
Modifies the Origin position at Runtime.
Description:
This code makes usage of a property node to modify the Front Panel origin position at runtime.
Requirements:
LabVIEW 2012 (or compatible).
Steps to Implement or Execute Code:
1. Run the VI
2. Modify the Vertical and horizontal position using the Desired origin control cluster.
Additional Information or References:
"**This document has been updated to meet the current required format for the NI Code Exchange.**".
