This example is of my LabVIEW palette which gives you access to the following VIs in LabVIEW 2012:
1. Media Burner
-Media Burn
-ISO Burn
2. Java API
-Compiler
3. Scroll Events
-Numeric Scroll
-Chart Scroll
-Array Scroll
In order to create this palette I followed these instructions. It is quite easy to make these palettes, you simply need to keep tabs on where your files are and how you then package them for distribution.
In order to install the palette simply unzip the relevant version and double click the install batch file. This will place all the necessary files in the correct location so that it will work in LabVIEW.
The following is a picture of my palette:
