Example Code
Labview Gaussmeter Magnetometer with Hall Effect Sensor Version 2
Code and Documents
Developed by Robert Emin
This is Version 2 which is a complete rewrite of the functions and internals.  Invoke Node has been used to reset memory values to zero after the session has been stopped.  A Gaussmeter or Magnetometer is used to measure the presence and strength of a magnetic field.  A hall effect sensor is commonly used.  In this documentation, the Allegro 1302 is used although the 1301 is shown in the schematics.  The author preferred the specifications of the 1302.  Gaussmeters are effective for measuring the quality of ferrite magnetic cores, air coils, EMC.  The hall effect sensor creates a voltage from the magnetic field.  From this, we can calculate the magnetic field from the formula given in the specifications sheet provided by Allegro.  Once this is achieved, a multitude of statistics can be performed on the information.
The option of saving the results to a text file is available to the user.  This program is intended for all uses and vocations.  This is the second edition. Resources provided, other versions may be issued.  Feedback is welcome.
Main Screen
Contributors
