Overview
Function overloading is common in object oriented languages. It allows the same function name to work with varied datatypes, and implement different functionality. The LabWindows/CVI compiler has a number of extensions to ANCI C, one of which is function overloading. This simple example demonstrates how to implement it.
Description
The example calls a function, add2numbers, three times. On each call the function is passed two numeric data parameters of a different type (float, double, integer), that it adds together, and returns the result.
Hardware and Software Requirements
No hardware is used in this example.
- Download the attached zip file (Function Oveload.zip).
- Extract the five files contained in the zip file to a folder.
- Navigate to the folder with the extracted files and open the 'Function Overloading.prj'.in LabWindows/CVI.
- In the project open the Window>>Debug Output window to view the results of the addition.
- Build and run the code, and view the results in the Debug Output window.
- Examine both the 'Function Overloading.c' and 'Function Overloading.h' files to see how the function add2number() is declared and defined for each datatype.
There is further information in the LabWindows/CVI help, section: Programmer Reference>>LabWindows/CVI Compiler Overview>>C Language Extensions
David C
