Example Code
LabVIEW and ONNX Runtime (artificial neural network)
Products and Environment
    Operating System
  • Linux
  • Windows
    Programming Language
  • C
  • C++
  • LabVIEW G
    Other
  • ONNX Runtime library
Code and Documents
Third-Party Code Repository
Some users manage their code in repositories outside of ni.com. Use your best judgment when following links to third-party sites. https://github.com/IvanLisRus/LabVIEW-ONNX_Runtime
Description
This example demonstrates how to use an ANN (artificial neural network) in LabVIEW.
It includes a wrapper over the ONNX Runtime, allowing you to:
  • initiate ONNX model;
  • obtain input/output information and metadata;
  • load data into ANN and obtain results.
Image processing is implemented using the following logic:
Stage 1: Detection (YOLOv8n ANN):
  • Convert the [1024, 1024] image to a [1, 3, 1024, 1024] tensor and feed it to the ANN input
  • Convert the data received from the ANN to a readable form, filter by threshold and NMS
  • Display the detection result
Stage 2: Rotation angle compensation (custom ANN):
  • Image segmentation (based on the results of stage 1)
  • Image resizing [x, x] -> [512, 512]
  • Convert the [512, 512] image to a [1, 3, 512, 512] tensor and feed it to the ANN input
  • Convert the [sin, cos] data received from the ANN to an angle and compensate for it
  • Display the result (segmentation, scaling, rotation)
Stage 3: Identification (ANN EfficientNet-B4):
  • Image resizing [512, 512] -> [380, 380]
  • Transform image [380, 380] into tensor [1, 3, 380, 380] and feed it to ANN input
  • Transform data received from ANN into probabilities for each of the two classes [Avers, Revers]
  • Display result
Example using VIs
Example using Class
Related Links
LabVIEW ONNX Runtime (code) on GitHub: https://github.com/IvanLisRus/LabVIEW-ONNX_Runtime
ONNX Runtime on GitHub: https://github.com/microsoft/onnxruntime/
Demo Video: https://youtu.be/AT9D4SQ7oe0 or rutube.ru
On Windows OS, you may need to install Microsoft Visual C++ Redistributable: https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist
Contributors
