Example Code
LabVIEW Version Information Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI gives the version of LabVIEW used for the development and the version of the executable in case you run it into an EXE file
Description
You can also use this VI to display company information, address and e-mail contact. It is also recommended to customize it with a photo in the background instead of the white decoration, or any other design. The given one is a template. Also note that this VI is very valuable when used in a build application like an executable. If you are using the LabVIEW project, go to Build Specifications for creating an EXE file. Place this VI inside the source Files
Requirements
LabVIEW Full Development System 2012 or compatible
.NET Support
  1. Run the VI
  2. To stop the VI, click on the box
VI Block DiagramLabVIEW Version Information Using LabVIEW BD.jpgLabVIEW Version Information Using LabVIEW BD.jpg
**This document has been updated to meet the current required format for the NI Code Exchange. **
Comments
BetaCommunityCo
Member
Member
on
When to use it
Hey, great example!
Users should note that this VI is very valuable when used in a build application like an executable. If you are using the LV project then go to your Build Specifications for the EXE and then to Source Files and put this About box in the Dynamic VIs.
BetaCommunityCo
Member
Member
on
good
this is a good example but need .NET support
BetaCommunityCo
Member
Member
on
Very usefull
With 2 Labview release every year, we need this to fix software issues. If I use this in my project, i'll customize it to display : "If application hang : Feel free to call STEP to fix it"
See you soon :P)
DanRichards
Member
Member
on
Extremely useful and part of a smart developer's toolkit, but hard to find. Would you mind adding some keywords? I would suggest the following as I used them while searching:
"About.VI" and "About VI"
"application version"
read get update programmatically
"Version Information"
"Version Number"
"Auto Increment"
Thanks to the original developer and whoever helped him/her figure this out. Maybe this should be part of a DevZone article for tips to make your application professional? Or just a KB?
-Dan
Dan Richards
Certified LabVIEW Developer
