Example Code
LabVIEW Java Compiler
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
Attached is a VI that will allow you to compile Java code straight from LabVIEW 2012.
Description
The VI works by creating a batch file which is used to run command prompts which call the relevant commands to compile the Java code using the JAVA JDK compiler.
I have attached a simple Hello World Java code which you can use to test this VI.
Please note that it is possible to download my other example which shows the creation of Palettes. This will include the software required and all the VIs and the only thing you need to do is run an install.bat file.
Also, note that I will be further developing this to add the java text editing into LabVIEW as well.
Requirements
  • LabVIEW 2012 (or compatible)
  • JAVA JDK compile
  1. Unzip the attached folder to your computer
  2. Create your Java code using notepad or any other text editor.
  3. Open the VI "Compiler.vi"
  4. Set the Java file path to the location of your Java file.
  5. Run the program and it should compile your Java code and create the necessary class file.
  6. The compiler will finish by running the Java application.
VI Block Diagram
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
Comments
meddeb.safouene@gmail.com
Member
Member
on
I am using the block Open URL in Default Browser.vi (Labview 2013). i want after the browser open my URL close it automatically after few seconds . can any one help me please
Best Regards
