Example Code
LabVIEW Guitar Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview:
This VI plays recorded sound files, from an actual guitar
Description
This code work like an actual guitar, the strings are elongated boolean buttons who's mechanical action is 'Latch When Pressed'. The structure of the code uses events, and the control type is set to Mouse Enter. Essentially, when your mouse passes within the range of the 'string', it activates the relevant event, causing it to play the sound file.
Requirements:
  • LabVIEW 2012(or compatible)
  1. Run the vi.
  2. Move your mouse across the strings, and listening to the sound
ShalimarA | CLA
Comments
Mayayi
Member
Member
on
hi,
I can't run it, my Labview Version is 2011 but i think this program version is 2012!
Please save 2011 format.
ShalimarA
Member
Member
on
There you go, I've attached a version suitable for LV 2011 as well.
ShalimarA | CLA
Rob_Ward
NI Employee (retired)
on
Nice code Shalimar.  Hows about adding keyboard features so you can play more notes?
Robert Ward
Applications Engineer, NI
Matt_McLaughlin
on
I was thinking the same thing! Great UI and it's impressive how simple the VI is!
Using the keyboard to represent frets would be an amazing addition.
-Matt
Matt
NI Community Team
ShalimarA
Member
Member
on
Thanks for the comments, guys!
I'm definitely going to be implementing frets and chords into the piece as soon as I get a chance to, any other suggestions would be great!
ShalimarA | CLA
