Overview
The example demonstrates how acquire data from magnetometer
Description:
A Gaussmeter or Magnetometer is used to measure the presence and strength of a magnetic field. A hall effect sensor is commonly used. In this documentation, the Allegro 1302 is used although the 1301 is shown in the schematics. The author preferred the specifications of the 1302. Gaussmeters are effective for measuring the quality of ferrite magnetic cores, air coils, EMC. The hall effect sensor creates a voltage from the magnetic field. From this, we can calculate the magnetic field from the formula given in the specifications sheet provided by Allegro. Once this is achieved, a multitude of statistics can be performed on the information.
Steps to implement or execute code
To implement this example:
To execute this example:
Requirements
Software
LabVIEW 2012 or compatible
NI-DAQmx 16.0 or compatible
Hardware
cDAQ with C series analog Input Module or compatible DAQ devices.
