The following example code is provided in the LabVIEW NI Example Finder under Hardware Input and Output»DAQmx»Analog Input»RTD or Thermistor - Continuous Input.vi. The front panel of this example allows the user to:
Making an RTD or Thermistor Measurement in LabVIEW
Measuring Temperature with Thermocouples, RTDs, and Thermistors
Related-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
There's also this tutorial from Dracal Technologies that shows how to get RTD data into LabVIEW very simply using their RTD transmitter, with ready-to-use downloadable templates: https://www.dracal.com/en/how-to-rtd-pt100-sensor-labview/.
This may be an option to consider.
