Example Code
LabVIEW Embedded Module Blink Example
Code and Documents
Description: This example uses an MCB 2300 ARM target and the LabVIEW Embedded Module for ARM Microcontrollers to control an LED on the ARM development board causing it to blink.  This example requires LabVIEW 2010 or later and the LabVIEW Embedded Module for ARM Microcontrollers. To run this example just open the project and run Blink Main.vi. This will compile and download the code to the ARM development board.
Block Diagram:
Kevin Fort
Principal Software Engineer
NI
Contributors
