Example Code
LabVIEW Continuous Integration (Jenkins/GitHub)
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
These example files are to be used in conjunction with the LabVIEW Continuous Integration Tutorial (Jenkins/GitHub).
The tutorial uses these files to illustrate how to graphically diff the source code submission of a Pull request when using Git repositories. It also demonstrates using Jenkins to automate the submission and build process.
Description
Using the LabVIEW Continuous Integration Tutorial, these files (which include LabVIEW VIs and scripts) are placed in separate repositories to automate Jenkins pipelines to:
  • Build a LabVIEW Build Specification
  • Perform Unit Tests
  • Perform a graphical diff of a Pull Request submission on GitHub
Hardware and Software Requirements
Place these files in the appropriate directories per the LabVIEW Continuous Integration Tutorial (Jenkins/GitHub).
