Example Code
LabVIEW Basic Backup
Code and Documents
Overview
This example VI shows a way to back up your files or folders on a destination drive you specified.
Description
The app takes a list of folders either from the front panel or a simple txt file stored in the same directory and duplicates the files and folders on a destination drive you specifiy. It ingnores any files already present at that location so is ideal for photos or music.
This VI makes use of a few of the neat little file VIs in labVIEW like recursive file listing and check if file exists. It gives you a nice progress bar too.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Download and unzip the attached folder to your computer
  2. Open the project "Media Backup 2012 NIVerified.lvproj"
  3. Open the VI "Backup.vi"
  4. Input the path of the files or folders to backup and the destination drive
  5. Run the program
VI Block Diagram of "Backup.vi"
Nick
