Example Code
LabVIEW 3-State Logic Compare
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI compares inputs X and Y and returns X<Y, X=Y, or X>Y as a string output.
Description
A simple and useful VI that can either be used or easily added into a larger program with the drag-and-drop Snippet below. Two-users' defined inputs are subtracted, and the sign of the result (-1, 0, +1) is found by using the Sign.vi. By adding 1, a line-index is now created to be used with the Pick Line.vi, which outputs our logic comparison as a string.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open " 3 State Logic Compare 2012 NIVerified.vi."
  2. Specify your desired numerical inputs for X and Y.
  3. Run the program.
VI Block Diagram
Huntington W
***Don't forget to give Kudos and Accepted as Solution where it is deserved***
