Example Code
LabVIEW 2013 Web Service example
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
This example is built from the following tutorial. It demonstrates how a web service is hosted on a host PC as well as a real-time target. This functionallity has only been implemented in LabVIEW 2013.
Tutorial: Creating and Accessing a LabVIEW Web Service (Real-Time, Windows)
To run the web service, open the project, right click on the HostPC web service and select 'start'. You should then be able to navigate to
http://127.0.0.1:8001/PCWebService/AdditionalOperations/Subtract?b=3&a=4
Which will display the raw xml data for subtracting 3 from 4.
To do the same for a Real-Time taget, connect to your target and perform the same steps as above, but replace the 127.0.0.1 with your target's IP address.
Staff Certification Engineer
