Overview
This is the file for a previous Vision Development Module example. As of LabVIEW 2013, this example is no longer installs with the Vision Development Module examples. I've posted it here so that users who want the example in later versions of LabVIEW can have access to it..
Description
This example uses functions from the Vision Development Module to read data from a LCD display and output the data as a numeric
Requirements
LabVIEW and the Vision Development Module 2013 and later (for this file). If you have a version of LabVIEW that is earlier than 2013, the example should have installed on your system with the Vision Development Module
Front Panel
Block Diagram
Description-Separate-2Example code from the Example Code Exchange in the NI Community is licensed with the MIT license.
I would like to add a quick note here. The Smallest ROI size is 95x87. Anything smaller than this results in a ROI error.
Fusebox Inspection example has also been removed from newer versions of LabVIEW.
Would you be able to post a link to the old Fusebox example? Thanks.
