Example Code
Kollmorgan AKD drive communication via MODBUS TCP/IP
Products and Environment
    Hardware
  • Data Acquisition (DAQ)
  • Industrial Communication
  • Instrument Control
    Software
  • LabVIEW
    Operating System
  • Windows
    Programming Language
  • LabVIEW G
Code and Documents
Description
This is a collection of VIs I put together a few years ago to enable the control of a Kollmorgan AKD drive via LabVIEW over MODBUS TCP/IP. The various VIs included permit various tasks such as creating a new Motion Task, changing the Operational Mode of the drive and commanding a move. I no longer have access to an AKD to verify the functionality of the VIs, but they might still be of use for someone. N.B: they make use of the NI Modbus library, a copy of which is included.
How to Use
First, use AKD Initialise to open a connection to the drive. Then use the appropriate VIs to perform tasks as required. Once finished, use AKD Close to close the connection and exit.
OG
Research Engineer
