Example Code
Keyboard Event for Deadman Switch Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This code implements a deadman switch using the spacebar of a keyboard.
Description
When dangerous machinery is being operated, test operators may want to implement a deadman switch so that a keyboard key must remain depressed for the test to continue. This code will wait on the user to start executing and then the main loop will stop if the user releases the spacebar. The code uses two event structures, one to start the code to be controlled and one to stop the code.
Requirements
Software
LabVIEW 2013 (or compatible)
  1. Run the VI
  2. Press the spacebar
  3. Release the spacebar and the VI will stop running
Additional Information or Reference
Rob B
FlexRIO Product Manager
