Example Code
Keyboard Controlled Cursor Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
Overview
This example was written to show how event structures and property nodes can work together to move a cursor on a graph by using keystrokes.
Description
In the attached example, certain letters on the keyboard (A, D, W, and X) are programmed to move the cursor in certain directions by using event structures. Other properties are also made available for the user to modify during run-time. Instructions are also included for how to exclusively use the keyboard to execute the VI.
Requirements
  • LabVIEW 2012 (or compatible)
  1. Run VI
  2. Following buttons of the keyboard are used to move the cursor
    "A": Move cursor left
    "D": Move cursor right
    "W": Move cursor up
    "X": Move cursor down
  3. Use the direction arrows to change the cursor lock option
Reference
How Do I Programmatically Create a Cursor for a Graph in LabVIEW?
VI Block Diagram
Robert B
RF Product Support Engineer
Comments
JAYBIOMEDICAL
Member
Member
on
THANK YOU.....
I WANT TO CONTROL CURSOR WITH USING KEYBOARD ON MY GUI.
SO CAN I DO THAT? & IF I CAN THEN PLEASE HELP ME WITH THIS
