Overview
Reads a (.java) Document from a compiler ( Eclipse, JavaEditor,etc.), searches for following variables ( int, double, or boolean) and defines them on LabView.
Description
At the moment, there are just two variables for each tipe: (int, double, or boolean) supported.
- Click on the file path (use dialog) button, browse and select your (.java) code from your computer.
- Run the VI and click the OK button.
- The defined variables (int, double or boolean) will appear automatically on your VI.
- You can rewrite your variables on your (.java) Program and then run the VI again, but it´s important that to compile the java code.
Requirements
Software
National Instruments Labview
Java Code compiler for example: (Oracle, JavaEditor, Netbeans)
Additional Images or Video
