Example Code
Intelligent XY Graph Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This simple example show how to implement and use an Intelligent XY Graph that allows you to choose the data for X Axis and the Y Axis during run time and edit time.
Description
This example uses X control to implement an XY graph indicator whose X and Y axis data could be changed during runtime. The changed plot will be shown on the graph instantly.
An subVI is also included which can be used to easily add data to the graph.
Requirements
  • LabVIEW 2013 (or compatible)
  1. Run Tester VI from IXYG project.
  2. Change the X and Y axis data during runtime and inspect the change.
VI Snippet of  Tester.vi
Demonstration Video
 **This document has been updated to meet the current required format for the NI Code Exchange. **
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
