Example Code
Integer to Binary Coded Decimal using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI converts an U32 to Binary Coded Decimal. Each digit can take up to 4 bits, so two digits can fit in to a single U8. This can be optionally toggled
Description
Requirements
Software:
  1. LabVIEW 2015(or compatible)
  1. Open the VI
  2. Input a number
  3. Observe that the output matches
VI Block Diagram
Tanner B.
Systems R&D Engineer - Aerospace, Defense, and Government
Comments
ecande
Member
Member
on
Can you please downconvert to earlier LabVIEW version? I have 2014, but the community may benefit more with a 2009 version.
tsplinter0
Member
Member
on
Very nice algorithm, it is well documented and simple.
However I think the input should be unsigned. It seems to go into an infinite loop when the input is negative.
An easy fix, thanks for the code..
Tanner!
NI Employee (retired)
on
Good catch. I'll change the example and re-upload.
Tanner B.
