Example Code
Insertion sort and use of pointers for memory addressing with LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Description
This demo application shows the use of the LabVIEW dll library functions for creating pointers and memory addressing by implementing the insertion sort algorithm. Primitive VIs to memory allocation and deallocation as well as for reading and storing data have been implemented. Malleable VIs are also used to allow the use with different data type without changing in code.
Prepended data size provides high flexibility simplifying the use of primitives, especially with unbounded data types, at the expense of the overhead of 4 prepending bytes for the length.
