Overview
This VI allows the user to insert a marker or flag alongside data points in a measurement file while the file is being written. As the data is written to a file, a marker column is added (with a tab separator between columns).
Description
Ordinarily, the program writes an empty string constant to the marker column. When the user presses the "Return" key, a user specified string is written to the column instead. The user can change the string at run-time if different flags need to be written in the same file. This is useful when using an external program (such as Excel) to analyse data, as it provides an easy method to find a specific location in the data after acquisition is complete and the file has been saved
Requirements
1.Setup a data source (DAQmx read, VISA read, etc.) within the while loop
2.Run VI
Block Diagram
