Example Code
Index Cluster with Event Structure in LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This VI is an example that demonstrates how you can create a event structure based on a value change in a cluster.  The VI then extracts the index of the element in the cluster whose index was changed.
This example is useful because extracts the index of the element in the cluster that has been changed.
Description
Use Event Structure to handle any value change in the cluster elements. The property node Controls[] of Old Values and New Values allows to compare both and determine which element of the cluster has changed.
Requirements
LabVIEW 2012 (or compatible)
  1. Run VI
  2. After running the VI, change the value of one of the controls in the cluster on the front panel.  The index of the control you modified will be displayed in the control to the right
Ben
Certified LabVIEW Associate Developer
Certified TestStand Developer
