Example Code
Import Custom Scale Data From TDMS File Into MAX
Products and Environment
    Software
  • LabVIEW
    Driver
  • NI DAQmx
Code and Documents
Overview
This example shows how to Import a Custom Scale Data From TDMS File and transfer into MAX
Description
This code pulls custom scale data stored in a TDMS file, packages it, and saves it as a scale in Measurement and Automation Explorer.  The scales are stored in the TDMS file as a group.  The parameters, like slope and intercept for a linear scale, are stored as the data for that group.  The name, scale type, units and description are stored as properties of that group.  This program will not overwrite or delete any existing scales in MAX.
Requirements
LabVIEW 2012 (or Compatible)
  1. Run VI
  2. Open MAX and look at Scales
Main VI Snippet:
Custom Scales from TDMS File to MAX LV_2012_NI_Verified.pngCustom Scales from TDMS File to MAX LV_2012_NI_Verified.png
Chris Bakker
SET Americas
CEO
