Example Code
Import 3D Models from Google SketchUp into LabVIEW Using LabVIEW
Products and Environment
    Software
  • LabVIEW
Code and Documents
Overview
This example introduce LabVIEW 3D Picture Control is a powerful tool that can be used to easily visualize and overlay data on real-world objects by using the Sensor Mapping Express VI
Description
This example it can be difficult to locate existing models of bridges, vehicles, buildings or any object you may want to import and model
Requirements
  • LabVIEW 2012 (or compatible)
  1. Open SketchUp and click Get Models
.2. Search for your model and select it
  1. Once your model is imported, select File ? Export ? 3D Model. Save the .kmz file to your Desktop.
  2. Rename the .kmz file to .zip (for example, rename tumbler.kmz to tumbler.zip)
  3. Open the .zip file and locate the. dae file (located in the models folder inside the zip file)
  4. Open the. dae file in MeshLab
  5. In MeshLab, select File 》Save As...
  6. Select STL File Format (*.stl) and save your model (tumbler.stl for example)
  7. Now can run this Load Model example to load model selected..
LabVIEW Front Panel
Comments
I.Foldvari
NI Employee (retired)
on
This is great.
I was looking for a way to use Google Sketchup with the 3D SensorMapping for long !!!!!
Great job.
Regards
Ingo Foldvari
Area Sales Manager - US West Academic
Alvarez
Member
Member
on
I download de evaluation vesion of labVIEW 2012, also the example that are in this link https://decibel.ni.com/content/docs/DOC-6033, so when i run the programm labVIEW throw me an error that says "Memory full", and i just want to make a prove to know how to load a stl file, what can i do in this case ?
I've done all the procedure of this page for the transformation of the file.
AndreasStark
on
There is also a plugin for Sketchup to do STL export: http://sourceforge.net/projects/stl4su/
Just put it into the C:\Program Files (x86)\Google\Google SketchUp 8\Plugins folder. Then in Sketchup go to Tools > Export to STL
But the easiest way is to export dae from Sketchup since from LV 2011 the picture control can import these as well (use invoke node App.Scene.Read Scene File) as described here: Import and Simplify CAD models in LV Robotics 2011
Maybe you need to add an autofocus invoke node to the picture contol
Andreas Stark
LabVIEW Lead @ Rocket Factory Augsburg
salik44
Member
Member
on
I followed the procedure mentioned above, but it gives some sort of error "memory full" please help me out
