Overview
Generation of a simulated signal with enough harmonics to verify THD measurement accuracy.
Description
In the case of simulation, the output of sine wave generator is very pure (total harmonic distortion is approximately zero). Sometimes, we need a standard harmonic generator, used to verify the THD measurement accuracy. A common practice is to use multiple sinusoidal signals of different frequencies to synthetic harmonic signal. However, this can be troublesome for higher harmonic number.
A simpler way to accomplish this is using a pure triangle wave to replace the harmonic generator. Fourier analysis tells us that the triangular wave contains many harmonics, and its THD is a constant. Now we complete the simulation of harmonic signal.
Requirements
LabVIEW 2012 or compatible
Steps to Implement or Execute Code:
1. Run the VI
2. Change frequency and amplitude
3. Finish execution with the stop button
